Home Forum Ask A Member Johnson rd-14 Cowling Screws
  • #201203
    trex014
      I recently bought a 53′ RD-14 and two RDE-16’s that I am going to setup twin motors on the back of my aluminum boat. All three motors are missing all but one single screw to hold on the cowlings. I have the parts manuals for this motor but I cannot find these screws anywhere. I know they are simply machine screws so if anyone knows the length and quantity I need I have a hardware store that carries most lengths. Any help is very much appreciated!
      #201204
      MIKE SIMS
        RD-14 and RD-16 show the same Part #s. I assume you want fig. #3 and #4 so here are the part #s
        They are pictured with the cowl
        fig#3 300634
        fig#4 301682
        RD-160002
        RD-160001
        • This reply was modified 5 years, 10 months ago by MIKE SIMS.
        • This reply was modified 5 years, 10 months ago by MIKE SIMS. Reason: add pictures I hope
        #201211
        olcah
          Aubuchon Hardware here (Maine) has little drawers that contain stainless 1/4-20 screws with heads like these photos that are very near the original appearance. (The originals are plated steel I believe.) I got the 3/4 inch length and shortened a couple with a hacksaw for the cover threads near the manual rewind. If too long they hit the rewind. I’d get about 12 screws to start with. Do not overtighten these as the thread in the cover halves is short and strips easily.
          To replace screw number 7 I used a longer 1/4-20 screw, just plain plated. I think I turned down the head diameter to fit the spark plug cover recess. I made the bushing on a lathe from aluminum.
          Good luck with your interesting project.
          100_6535
          100_6536
          • This reply was modified 5 years, 10 months ago by olcah.
          #201221
          trex014
            Okay thanks! I figured I would have to get a handful of screws and cut them to length. The only issue I forsee with that is messing up the end threads, is that nothing to worry about or is there a way to clean up the threads after I cut the screws to length?
            #201226
              put a nut on before cutting then I grind the end then remove the nut,
              #201227
              olcah
                After I saw them off I file around the cut end with the file at 45 degrees. Stainless files rather hard but with patience and a good file it can be done. You can also use a grinder, belt sander, or lathe to help. You just want to smooth up the cut end of the thread at about 45 degrees. Get a plain steel 1/4-20 nut to try onto the thread so you don’t force the aluminum threads in the cover. Also if you buy about half of the screws at 1/2 inch long they would be fine. You need the longer 3/4 inch length to go horizontally through the cover sides and locate into the rubber mounts. Actually I have one or two spares 1″ long as they sometimes make it easier to line up into the rubber mounts. It takes some patience to get the covers lined up so the screws go into the rubber mounts but you will see as you go.
                These motors are fun to run but really vibrate and I usually have a couple spare screws aboard.
                #201228
                olcah
                  100_3589
