Home Forum Ask A Member Johnson TD 20
  • #175416
      Hi
      New to this site. I’m trying to get a TD 20 running. So some help would be appreciated.
      So I need leather washers for push primer.
      Also want to change plug wires but noticed their soldered to the coil. Can they be changed? I wanted to put regular boots to connect to spark plug.
      Thx
      Calmsea
      #175417
        http://pochefamily.org/outboard/CarbService.html
        #175418
        JOHN D.
          You can cut off the spark plug wires near the coil and leave a tail of bare wire soldered to the coil. Just twist on the new wire to the tail. That way you don’t risk ruining the coil from heat.
          #175443
          lloyd
            For Leather Primer Seals and instructions with diagrams to install them send $10.00 cash per set (no checks) and a SASE ( Self Addressed Stamped Envelope) to:
            Lloyd Lautner, 9289 North Long Lake Road, Traverse City Michigan 49685
            #175447
              Great, thx for the info. I love that little 5 hp motor.
