Home › Forum › Ask A Member › Johnson TD-20: Looking for some input…
- This topic has 18 replies, 11 voices, and was last updated 10 years ago by
aquasonic.
March 22, 2016 at 3:18 am #3893
Hello, trying to get a TD-20 running for my Dad. I have been able to find some information on the old unit (mostly from AOMCI…thanks!) but still have some questions. Initially I purchased the outboard from an older gentleman who claimed "ran great a couple years ago when I last used it"… Long story short I was unable to get the outboard started at all with fresh fuel to the carb. The carb would constantly slowly leak fuel. I would say the outboard is in fair to good overall condition for its age.
The engine does have compression and spark looks good and consistent. It will start and run briefly with carb cleaner sprayed directly into the cylinders. I have the carb off now, have ordered a Mercruiser style float to hopefully retrofit in place of the original cork one. The cork float does float when tossed in a bowl of fuel now but has been dry some time, not convinced this is the main issue.
I’m not familiar with the fuel system works on these but have a basic understanding. With the carb removed I can spray carb cleaner or fuel mist into the "intake" and the the outboard will not attempt to start or even pop. I can feel no suction at this port. Is this normal?
Does anyone know if Loyd still sells the leather primer cups? I’m thinking I should purchase some regardless if available.I would greatly appreciate any help or advice at all!
March 22, 2016 at 4:30 am #33770XJ,
Those T Johnson carbs can be finicky. Check out this site for lots of good info.
http://www.pochefamily.org/outboardMarch 22, 2016 at 10:22 am #33776I actually modified a mercury float, to work in a similar carb. It’s a plastic float and the buoyancy is great.
Those old TD’s are still very common today, so if you need anything, several here seem to have what you need.
Make sure that you mix the fuel, at 16:1
Points set at .020
Spark plugs: .030Speaking of Lloyd, where is he?
March 22, 2016 at 11:06 am #33779The primer must work to start engine.
March 22, 2016 at 11:11 am #33780Mr.Lautner was still selling leather washers as recently as a 2 months ago.
March 22, 2016 at 11:32 am #33781XJ, these are great, reliable motors and are a ton of fun to work on. You’ll want to completely go over the carburetor and the link Dave gave you will show you how to do it.
Since you have the motor apart, cleaning the points will not hurt either.
And don’t be afraid to ask questions!
March 22, 2016 at 12:51 pm #33787Anonymous
Using carb cleaner and starting fluid can damage a motor.
Use gas/oil mix in an oil squirt can to prime the motor.Steve A W
March 23, 2016 at 4:58 am #33820quote Steve A W:Using carb cleaner and starting fluid can damage a motor.
What he said x2 ^^^^^^^^^
March 23, 2016 at 8:39 pm #33835quote mercuryman:The primer must work to start engine.How true that is. With no choke, a good working primer is a necessity. Sounds as though your motor wants to go, but just needs a complete carburetor breakdown/clean/rebuild. I think that most will agree, the pochefamily website is a great resource for the carb rebuild as well as other topics.
Regarding the primer washers, Lloyd L. would be my first choice. I have purchased them NOS from marineengine.com, but they may or may not have them. Seaway Marine is another one to try. Here’s a link to a business that has reproduction washers:
http://www.effenaco.com/store3/viewitem … oductid=28As SteveH wrote, "don’t be afraid to ask questions".
Improvise-Adapt-Overcome
March 24, 2016 at 1:53 pm #33854http://boatinfo.no/lib/johnson/manuals/ … on.html#/0
