Home Forum Ask A Member Johnson TD 20 magneto
  • #232918
    mercuryman
      Has anyone tried OMC coils on TD 20 type magneto ?
      #232919
        if you are referring to the usual coils they are not made for the TD common coils began to appear on the TN version around 1952
        or… are you asking if the windings can be transferred on the TD laminates
        • This reply was modified 5 years ago by JACQUES.
        #232923
        mercuryman
          Can the OMC coil windings be transferred to TD laminates ?
          #232924
          aquasonic
            Good question. If they do in fact fit, the wiring is quite different. Why not find good used coils. There are tons of used ones around.
            Improvise-Adapt-Overcome
            #232939
              there has been cases where the winding of “modern” … coils was transferred over and it involved some work altering the laminates to fit the coil openning…. I do not remeber which ones could be rigged to accept the newer windings .
              I think it was in the Outboarder magazine some time ago so if you access to od copies see if you can find the procedure.
              of course if tons of used one are floating around that is your best bet .
              #232979
                Most of those old center-magnet coils are still good. That was before OMC discovered how to make coils that would self-destruct within 3 years.
                #232980
                  funny πŸ™‚ πŸ™‚
                  #233070
                  JOHN HOLBIK
                    Funny but true.
