Home Forum Ask A Member Johnson TD 20 Propeller ?
  • #3676
    mercuryman
      Will a Johnson TN-25,26,27,28 propeller fit on the TD-20. The part # are different but dimensions look the same.
      #32330
      aquasonic
        I don’t think they are interchangeable. The two props have different configurations. You might have to swap the propeller shaft to make that work.
        Improvise-Adapt-Overcome
        #32342
          Swapping the shafts isn’t going to happen. Very different lower units.
