Home Forum Ask A Member johnson tn 26 issue
  • #253234
    Brian Collins
      i have a great tn 26 motor except it revs up and down too much instead of being steady and backfires occasionally…
      #253239
        Could be running lean. Perhaps sucking air into the crankcase somewhere,
        or carb needs adjusted richer?
        Brian Collins
          i put in 2 more quarts of fuel and it ran much much better. peharps the motor was tilted wrong with a low tank while in my test barrel and it was getting starved or maybe the low part of the tank screen is a little plugged up…but the fuller tank made all the difference
          #253258
            Always good to start with the simple stuff, glad it worked!
