Home › Forum › Ask A Member › johnson tn motor screws needed
anyone know where i can get the mounting screws/lock washers for a johnson tn gas tank?…i need 2 of them.
The tank is bolted on with four common 1/4″ x 20 tpi bolts, found at any hardware store. Or you can order them from Marine Engine at $10.49 a piece!
http://www.marineengine.com/newparts/part_details.php?pnum=OMC0306418
I believe that the originals were stainless, with split lock washers.
Improvise-Adapt-Overcome
OK
