Home › Forum › Ask A Member › Johnson TN28
- This topic has 4 replies, 4 voices, and was last updated 5 years, 3 months ago by
JACQUES.
December 4, 2020 at 1:34 pm #224219
Just bought a TN28. Can you tell the year from the serial number? SN 969119.
This is a one owner unit. Original paint is near mint, with only very minor loss. Decals have yellowed a bit, but are nearly completely intact. Got it from the great-granddaughter of the original owner. Now to get it running. Last started the year it was bought.
December 4, 2020 at 2:16 pm #224221That would be a 1952 year model.
"Every time you remove a broken or seized bolt an angel gets his wings."December 4, 2020 at 4:55 pm #224227http://pochefamily.org/outboard/ also see red book URL in the picture below retype the url to the red book…. it covers TNs
http://www.pochefamily.org/outboard/CarbService.html
This reply was modified 5 years, 3 months ago by
JACQUES.
December 4, 2020 at 6:03 pm #224233Congratulations on your TN28! Great motor! And thanks to crosbyman for his link to the Pochefamily website. Please note that if you need new Leather Primer Seals with installation instructions as you almost surely will need them, I had to increase the price for seals to $10.00 several years ago. Very limited supply of the proper leather to make any more. I tried to contact David Poche some time ago to update the website, but no response.
Lloyd Lautner
231-929-7479December 4, 2020 at 8:24 pm #224269BTW tn 27 tn28s have good old magneto ignition… easy to service but you will have to pull the flywheel
http://www.leeroysramblings.com/johnson_magneto.htm
http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
the coils probably need to go….to
http://www.ebay.ca/itm/1-5-40HP-Outboard-Engines-Ignition-Coil-For-OMC-Johnson-Evinrude-584477-582995-/203046524200?hash=item2f46841528Joining AOMCI has priviledges 🙂
