Home › Forum › Ask A Member › johnson tn 26 gas tank question
the tn26 gas tank i have is dented but my question is the attached gas tank the same as a tn 28 or similar models
TN models tanks have two vertical holes through them. One for the carb adjust knob, and the other for the neutral clutch lever. TD models have no neutral clutch, therefor no clutch lever nor hole for it.
OK
