Home Forum Ask A Member just heads up…clutch and shaft binding CD
Viewing 5 posts - 21 through 25 (of 25 total)
  • #273460
      The forward gear bushing may have been set in place too far back in the gear housing.  I’m talking  a few thousands.  Put the gear case nose down on the bench and give the prop shaft a confident wack forward with a steel hammer.  Don’t mushroom the thing, just whack it. It may move the forward bushing enough just enough to put everything within tolerance.  I just ran into this on a 1976 six.
      #273462
        i’ll try anything   thanks     I’ll hopefully work on this tomorrow…. at 73 I have to balance chores and….fun
        #273481
          been reading lots of old posts  on shock absorber  size…. 6″11/16  seems the magic number … mine meaures  6″ 13/16 .
          while initially  working the housing  I recall it falling out  on the  ciment floor  and wonder if it got  messed up then ???   anyhow… pursuing the adventure
          GC gears turn fine on their own  but driveshaft turns about 3/4 turn and binds… on its own   . I’ll reinspect the  shock absorber  and  if  6″11/16 is the magic  number I’ll have my neighbour  tack weld it  at 6″11/16.
          “Spring has sprung”  …4C  and sunny  🙂 today
          #273518
            ok remeasured the shock and exactly 6 13/16   silly thing must have expanded when dropped on the floor   wacked it with a wooded hammer back to 6 11/16 perfectly
            will have it tacked
            now if I can find that silly  half moon key way   for the drive shaft pinion gear  i’ll will be on the road to success
            thanks all !!!
            🙂  🙂  update….key  found  !!!
            #273641
              update  March 09….
              Shock absorber  welded to 11/16    gear case  grinding gone 🙂    drive and prop  shafts   turn ok but a bit tight with all new  shaft prop seals and new impeller  normal I guess
              G C sealed up   to be tested….
