Home Forum Ask A Member JW 10 fuel inlet
  • #10330
    jbell13865
      What size helicoil would I use for a stripped fuel inlet? 54 Johnson 3hp. Is it regular course thread or pipe taper?
      #78346
      wagemaker
        Not sure of the answer to either question. Are you asking about the threads in the float bowl? I would take the fuel line out and check the threads against a thread gauge and go from there.
        #78359
          I believe that model has an inverted flare fitting on the pipe. Hole in the float bowl to match. If it is stripped, probably best cure is simply replace the float bowl.
          #78576
          bob
            If you need the carb bowl and spiraled copper gas line I think I have one.You can e-mail me at bob.miller58@comcast.net.Take. care.
