Where can I find inexpensive replacement head bolts for a beater JW-10 3hp I’m working on?
The factory replacement ones are $8.50 each, not including washers. They measure 1-1/8" long. The closest length the hardware stores have are 1" or 1-1/4". Will a 1-1/4" fit?
Also, the factory bolt is Grade 5. Should I stick with that hardness?
I just don’t want to spend over 50 bucks for 6 bolts for a $40 motor!
It seems OMC made a lot of their fasteners 1/8" shorter or longer than regular size bolts. Grade 5’s are plenty strong for your JW and if you find the 1 1/4" bolts are a bit too long and you don’t want to shorten them, 6 mil metric washers will stack nicely under the head and they are small in diameter just like the originals. 😀
I had brought the stock part # to my local dealer, and purchased one bolt so I could match it at the hardware store. The stock bolt was a Grade 5, so that’s what I bought. On this little motor, I’m sure most any grade would do though.
