Home Forum Ask A Member KA series crank removal
  • #261202
    GUY SCHMIDT
      Goodmorning gentlemen, I’m stuck….or at least my crank is stuck in the block! From what I could make out from my shop manual, the crank should slide out freely but the counterweight seems to be hitting the block. I have attached two photos that might help clear up any lack of wording on my behalf. Am I missing something in my procedure?
      Please help me get unstuck.
      #261205
        Not sure on this motor, but some have an external set screw to hold the
        crank center main bearing in the correct orientation and position.
        On some motors the center main is a slight press fit in the crankcase
        and require some heating the crankcase to get the crank out.
        Crankshafts aren’t designed for much of an axial “pressing”, so
        spacer blocks between the crankshaft webs are some times needed.
        stanley
          Have you removed the crankcase head?
          #261210
            There are two cast iron sealing rings on the cranks large rotary valve and since your motor shows signs of moisture having been  in it, they are probably stuck to the crank, just like piston rings stick to cylinder walls from rust. Soaking with your favorite penetrating oil should help break them free.
            In this photo you can see the grooves in the large bronze bearing which the sealing rings fit in and why they require an 8:1 fuel mix.
            KA-37-Rotary-Valve
            • This reply was modified 3 years, 9 months ago by Mumbles.
            #261220
              I see now that the 3rd Edition Johnson repair manual mentions
              this type of crankcase.
              GUY SCHMIDT
                Hello again, I finally got around to checking the info you guys supplied…..my motor still has the crank throw with way too tight a fit with the bronze rotor bushing. I tried to tap it through and it was met with too much resistance so I stopped. I was looking at the 10th edition and a much older one for info. and will keep searching. Thanks for all your help.
                #261579
                squierka39
                  Gus, the rings that were mentioned above are very tight. Getting the bottom counterweight past them can feel like it’s going to break, but it won’t. You just need to give it a good pull. I’ve taken a few of these apart. Lube it up some and pop it out. There two rings so it will do the same on the second one. There is no other way around it.
