Home Forum Ask A Member KE 4 recoil help
  • #3304
    ronboonville
      Working on the recoil. Is the allen screw that holds the sheave left handed? The recoil has a steel cable and only pulls out a little less than a foot. then stops. Any help?
      #29482
        Not sure if that recoil is similar to the Mark 5, but I gave
        up trying to get that allen screw out. I heated and beated
        and it would’t budge. I finally just ground off the minimum
        of the peen on the sheave post and took every thing apart
        that way.
          if it is off the motor that is how it works. the paws engage to far and lock it up0. the allen is right handed. unless you need to remove or replace the spring no need to remove the allen screw. 1 914 310 7086.
          #29507
          richardg
            If you have a broken spring the easiest way to get the recoil apart is actually to drill the head off that Allen head screw with a 5/16 drill. The head will fall off once you get to the shank of the screw. The remainder of the bolt unscrews easily.
            Use caution since the spring jumps out at you when it unwinds.
            If you heat the end of the old spring with a mapp gas or propane torch you can form a new loop with needle nose pliers. Heat and then Quench the spring end when you are done so it will hold its shape again.
            #29561
            ronboonville
              Yes David the recoil is off the motor, so maybe it’s ok. I’m just on the reassembly. Onward to the water pump!
              Thanks!
