First question is does anyone out there make fuel tank to AJ32 carb fuel lines using original type fittings? Secondly, is there a barbed fitting that screws onto the on/off valve assembly that then screws into the AJ32 carb? I want the ability to insert a fuel filter in the line form tank to carb. Due to age and blockage, I have removed the internal tank bronze filter.
