Home › Forum › Ask A Member › KG7 impellers
I seem to remember someone who will make impellers if you send the core. Can’t remember a name. Any help? Thanks
I USED A Sierra 18-3051 with a little rework on Ebay $10. or you can get a 47 21164 from John Macintosh mercury parts $40 + ship
Chuck, this might be the person you are thinking of.
Brian Wilcox 9231 Stone Road Algonac, Michigan 48001 (810) 794-7685
Also, Joe at Ferguson-Poole offers NOS impellers for $30. http://www.fergusonpoolemarine.com/enginecoolingsystem.html
That is the person. I used him in the past, but forgot his name. Ah, old age!
Mercury Part # 47- 21472 used on KF7,KG7 and KG4 on 5/8″ prop shaft
KE, Mark7 and KE7 use a different impeller on 9/16″ prop shaft
Gear case design is same. Parts differ.
Louis. I
the 9/16 and the 5/8 impellers are the same except for the shaft size. SO you can ream out a 9/16 tom 5/8 and ad a groove for the key if needed.
OK
