Home Forum Ask A Member KG7 Phelon with 20H stator and Condenser help…
  • #11389
    foodclub
      Asked this on JOMs and got no bites.
      I’m converting a KG7 from Scintilla to Phelon.
      KG7 specs are 398-713 for condenser and 398-716 for coil.
      20H specs are 398-693 for condenser and 398-173 for coil.
      1) I believe, based on the manual, and parts replacement data, that the two coils are, in fact, the same, so I think I’m good there.
      2) I am, however, using a 20H stator plate, which only accepts the 398-693 (20H) condenser. Manual specs on the KG Phelon condenser are .15-.19 cap. Manual specs on the 20H condenser are .14-.18 cap. What is the impact of using the 20H condensor on the KG7?
      Thanks (Always Learning!)
      #83722
        none that is within spec’s
        #83727
        76-j
          https://www.youtube.com/watch?v=OxPHe8EPe1Q
          The above video shows brass condensers , typical of most Phelon / Mercury ignitions. If you do this modification ever; using the OMC condenser that’s associated with the OMC coils, it will physically mount to the same tapped holes in the stator plate as do the brass condensors _________ 🙄
          #83728
            If it fits, it ships.
            #83768
            John Schubert
              It will work done it many times
