Home Forum Ask A Member KG7 tank recoil insert
  • #263120
    chuckw
      The tank is missing the insert to screw in the recoil screw. I have tried putting in a helicoil but gas does leak out of the top of the tank. I need ideas to fix the issue aside from finding a new tank. All help is appreciated.
      Chuck Webster
      #263121
        Using one of the tank sealers on the
        inside might be worth considering
        #263131
        jp53-n
          I’ve got a bunch of tanks available, but shipping might be cost prohibitive.
          #263152
            For what it’s worth, I am not following the question….if the insert is MISSING, what did you put the Heli-coil into?
            #263154
              II have been led to believe
              that if you ship a from a company facility like
              fedex to another of their locations near you,
              where you can go pick it up it, cost less than
              having it delivered to your door. If that is true
              and you have one nearby you may be able to
              save a few dollars that way.
              • This reply was modified 3 years, 8 months ago by Tubs.
              #263158
                how about a sealer on the screw and threads? unless it is the tank cracked. being on top don’t fill all the way. like a vent.
                #263165
                  Redneck repair would be to epoxy a stud in the hole, and use a nut to hole the rewind on.
                  Much better than duct tape too, lol
                  chuckw
                    At this point I soldered in the helicoil, but will probably need a new tank.  ( the whole inert was missing.)
                    • This reply was modified 3 years, 8 months ago by chuckw.
                    #263172
                    chuckw
                      How much are you asking?  Do you have any pics of the tanks? I may be willing to pay for shipping.
                      #263183
                        I missed the first part. You can try this.
                        Might want to use some sealer when install the
                        insert and defiantly on the screw when you put it in.
                        https://www.youtube.com/watch?v=FJ4gF2tXRBE
