Home Forum Ask A Member KG9 Mercury corrected to KF9.
Viewing 5 posts - 21 through 25 (of 25 total)
  • #226775
    Quinton Huxoll
      The serial number is 378200. The first obstacle it appears is coming up with a set of drive gears and am not very optimistic. Any info or advice on this matter as will as others is particularly welcome. The looming problem that will always be hanging around of course is the seized motor. Until that is addressed my decisions on other matters are sort of in limbo. Q
      #226776
      Quinton Huxoll
        Great alternated colors. Never thought about it……but it is my head now.
        #226819
        opposedtwin
          Quinton,
          When you say drive gears, you mean gear case gears, right? The magneto is also driven by anseries of fears. (see previous pics)
          Scott
          EDIT: I guess the picture I was referring to is in bruceter’s fine video at about the 1:15 mark.
          https://m.youtube.com/watch?v=e6UU74C_Jrs
          • This reply was modified 5 years, 2 months ago by opposedtwin.
          #226956
          Quinton Huxoll
            Yes I did mean pinion gear and propeller shaft gear………….I knew the distributor is gear driven but those gears did not cross my mind.
            #227289
            Quinton Huxoll
              Good video, Great outboards………makes me a little more determined to make this one run….. if a few of the issues can be overcome.
