Home › Forum › Ask A Member › Lapping flywheel
- This topic has 6 replies, 6 voices, and was last updated 3 years, 2 months ago by
amuller.
December 3, 2022 at 4:46 pm #269640
I found a good replacement flywheel for my Johnson FD-12 project to replace the original one with a damaged taper and a couple of cracks in it. I now need to lap the replacement wheel with my replacement crankshaft and got to wondering how other folks do the lapping process. A few methods I’ve read about in the past include:
- Put the flywheel on the crank and turn it around and around in the same direction for a few revolutions.
- Put the flywheel on the crank and rotate it one full revolution in one direction, then rotate one full revolution in the opposite direction. Repeat a couple times.
- Put the flywheel on the crank and rotate it back and forth thru a 90 degree arc, lift it up and turn it 90 degrees from the original starting position and rotate it back and forth thru 90 degrees again. Repeat until a full circle is completed.
- Put the flywheel on the crank with the flywheel and crank keyway slots aligned, then rotate back and forth through a 15 degree arc either side of the crank keyway slot (30 degree total arc).
Even though the key doesn’t hold the flywheel in place, it seems like the last approach would help to ensure the best mating surfaces for the flywheel in it’s final installed position. Regardless of what approach is used, I know to protect the upper crankshaft seal area during the lapping operation.
Anyway, not wanting to start an opinion battle here, just curious what others have done!
"Every time you remove a broken or seized bolt an angel gets his wings."December 3, 2022 at 5:07 pm #269641Methods 1 and 2 can cut grooves into the pieces. Method 3 is my chosen way.
Lapping a flywheel is the same as lapping valves by hand. Back and forth, lift and turn 90°, repeat until and even surface appears. A pencil line is drawn across the new surfaces and the pieces turned slightly to check for contact. The pencil lines should disappear.
December 3, 2022 at 8:58 pm #269648Mumbles – thanks for the input. Never thought about the comparison to lapping engine valves, but that makes good sense.
"Every time you remove a broken or seized bolt an angel gets his wings."December 4, 2022 at 12:38 am #269650Several years back I successfully lapped a 40 hp Johnson flywheel using Mumbles method .
Monte NZ
December 4, 2022 at 10:42 am #269656Not sure if my aging eyes could see the pencil mark very good.
How about magic marker or bluing, then rotate the flywheel 360?Prepare to be boarded!
December 5, 2022 at 10:41 am #269681Hello, other point is which abrasive grain good for flywheel?
January 3, 2023 at 8:31 pm #270637I would use method #3.
Some Chrysler manual provide a lapping procedure.
