Home › Forum › Ask A Member › Lauson Sport King 1947 OB 410
- This topic has 13 replies, 5 voices, and was last updated 2 years, 6 months ago by
Tubs.
September 14, 2023 at 6:44 pm #280610
OOPS ! please disregard my last message talking about the “twin coil” magneto. I realize now that you have a Lauson Single. My comments about coil substitutions pertain to the Lauson twin cylinder motors. I got side tracked by reading your posts to that older Lauson thread, that did indeed pertain to a twin cylinder model. I do not have first hand expierence with the single cylinder model, so I’ll defer to others on “no spark” issues.
Sorry about the confusion..
September 14, 2023 at 10:00 pm #280614No spark: Remove both spark plug wires & using a meter set on 10K ohms scale put either meter lead on each plug wire & see what the resistance is. If your motor was run with a plug wire off it may have damaged the coil. Should read about 8 to 10 K resistance. If it is infinate it’s bad, The secondary winding has two ends to the winding & both are spark plug wires. One fires when the coil fires & the coil has enough electrical energy still & “sees” the first plug going to ground thru the plug gap, the resistance now goes down & fires the other spark plug in a mirco second. If you have around 10K residtance, your coil is more than likely good.
Good luck
September 14, 2023 at 10:33 pm #280615Jeff, with due respect, you are describing a twin , floating secondary coil arrangement. I was off on that track too, and causing the OP confusion. The subject Lauson is a single cylinder motor.
See my previous post.
September 16, 2023 at 1:06 am #280631Hello…well we finally got the 1947 Lauson Sport King A410, cleaned up. My husband rebuilt the carburetor, put in a new single spark plug, cleaned everything he could and put in the gas and oil. He was able to “ spin” the motor but there was no spark at all. What should he check next? ( The little propeller sure looked cute while spinning around🙂)
Mrs. G,
If I’m not mistaken this is the magneto you have.
First Gary should clean the contacts with some fine sand
paper (around 400 grit) if he hasn’t already. It would be a
good idea to remove the wires to the points and clean all
that’s there to be sure you have good contact.
Here is a link on how to check your coil-
https://youtu.be/xPd8nMBTCkI
Replacement coils would only be available from other motors.
It is possible to make a replacement using a coil that is still
available but it requires considerable modification to the metal
plates of your original coil. I’ve done it but need to edit the
pictures for a video.
