Home Forum Ask A Member ld-13b 1968 johnson 5hp non shifting mdl
  • #221059
      Another issue with them is the spring loaded plastic friction shoe which rides on the mag plate to hold the timing/throttle setting. They wear out and the motors speed creeps down to an idle.
      #221126
        Dave…. thanks for the offer I did manage to just reshape the few nicks on the prop and it all looks good… new paint and it will be like new.
        Mumbles….the rib block is in top shape this engine looks pampered those blocks looks similar to the one on a 9.5 MQ I have
        opened it up this week ….new coils new everything under the fw even the wick looks new i’ll drop the lu to inspect the pump which I suspect will be fine like the rest of the motor
        thanks for comments
