Home Forum Ask A Member Lead paint?
Viewing 5 posts - 21 through 25 (of 25 total)
  • #255168
    bkrsdoz
      Meant to post 8 or 9.
      #255171
        Just joking!
        #255175
        green-thumbs
          Lead paint was not the best white paint in that it reacted with
          sulfur dioxide in air from coal fired stoves and furnaces and turned yellowish. Premium pain had Titanium Dioxide pigment that stayed a pristine white…under the soot and
          dirt from burning coal. I remember the good old days down side as my job was to pull the clinkers from furnace and fill
          stoker from pile of coal in corner of basement. We were
          fortunate, Some had to make do without central heating and
          Winters were longer and colder back then.
          That house when my grandfather owned it had a small coal
          stove to head a portion of upstairs where he lived, a single
          water outlet partial dirt basement and an outhouse back
          by the alley. My folks had a full basement, bath, kitchen
          and central heat installed. The coal furnace gave way to
          oil and eventually gas when it became available. I got
          elected to paint the outside of the house when I was 12
          The experience left me all in favor of child labor laws.
          Louis
          #255193
            Worked on a farm that had a gravity coal furnace. It burned rice size coal (3/16″ to5/16″). An auger fed the coal from a hopper into the center of the furnace. The coal was push up a tube where it would mushroom up onto a round plate to burn. The ash would drop off the side of the plate to the bottom of the furnace where another auger would take it out to a small conveyor. The conveyor would carry the ash up high enough for it to drop into a 5 gallon pail. The pail would need to be changed 2 or 3 times a day depending on how fast you were feeding the coal. The hopper held enough coal for a couple days, again depending on how fast you were feeding the coal. You could slow it down enough to last several days if you needed to be gone before the hopper would run out. You would have to pick the ash up off the floor. The ash was spread on the drive where needed. Next job was
            working at the coal yard that delivered that coal.
            #255207
              memories…
              we had a coal bin in the basement corner where big  bags of coal were dumped…dad had to shovel the stuff to keep the furnace shooting heat up in the  house   via a 4×3  floor grill .
              Dad,   a fireman , had to  fill the furnace at bedtime and early mornings before it  flame out .
              the high point came  when a 200 gal  oil tank was installed behind the house  and  a oil burner fitted on the  coal furnace  ….  happy   days  🙂  no more shovelling
              then came electric baseboards  years later …   next will be global warming…but I won’t  be around ….
