Home › Forum › Ask A Member › lead shots for carbs
- This topic has 10 replies, 10 voices, and was last updated 10 years, 1 month ago by
RICHARD A. WHITE.
February 1, 2016 at 10:09 pm #3538
So I ran into, yet another, 6hp carb where someone decided to plug the high speed air jet (which is not supposed to be done), causing the motor to flood/run too rich at anything much above idle.
In the process of pulling the thing apart to make sure there were no other occlusions, I have been trying to think of more cost-effective alternatives than paying $6-9 for a tiny lead shot.
Has anyone tried just using a fishing line sinker? They’re lead, and they’re small, and I can’t imagine why they wouldn’t work if installed carefully using an oversized punch lined up the right way. And to buy a pack of 50 for $2 seems to make a lot more sense to get the same job done.
Any other tricks or recommendations?
February 1, 2016 at 11:01 pm #31191I confess. I did it. Better yet, melt off a drop of solder and save the sinker for the fish.
February 1, 2016 at 11:08 pm #31192well, maybe in another 20 years I’ll catch up to the rest of you vets ๐
Thanks for confirming I’m not crazy.
February 1, 2016 at 11:25 pm #31196I have used solder as well.
Figured that out when I had to solder a water line up high in my ceiling joists, and I had all the little balls flying down at me due to my poor plumbing skills. Picked a little solder ball out of my neck, and thought hmmmmmmmmmmmm.
February 1, 2016 at 11:35 pm #31197Pull the shot from shotgun shells.
February 1, 2016 at 11:36 pm #31198Try melting some solder about a foot over a bucket of water. Makes perfect little balls when it falls in. Sort of like the old Remington shot towers that made lead shot for shotgun shells, but on a smaller scale ๐
February 2, 2016 at 12:03 am #31199Epoxy works wonders.
February 2, 2016 at 2:07 am #31208you can buy lead shot by the bag at reloading shops… buy the size you want
that should fix you up for a couple of generations ๐
Joining AOMCI has priviledges ๐
February 2, 2016 at 4:27 am #31213Solder may not be good. Nowdays it doesn’t contain lead. Lead is soft, which is a desired characteristic for sealing in alumnium carbs. Some solder contains acid for flux purposes. Might cause corrosion in the carb.
February 2, 2016 at 5:16 am #31214Not all shotgun buckshot or birdshot is pure lead. Some of it is a hardened alloy to retain its shape better when shot. If you use shot, make sure the bag says soft or pure lead. Find you a shotshell reloader and get a handful. It will last you the rest of your life.
