Home Forum Ask A Member Looking for coil and condenser for 1922-24 Johnson 2hp. Model BN. Serial 19098.
  • #170346
    Nordmann
      kenbarfoed@gmail.com.
      • This topic was modified 7 years, 1 month ago by Nordmann.
      #170356
      lyks2tinkr
        The Quick action magneto used in the early Johnsons were very robust and are nearly always good.
        Did you measure the secondary resistance?
        #170364
          • This reply was modified 5 years, 1 month ago by Tubs.
          #170366
          Tom
            ..and don’t forget that you have to either test for spark between the two wires, or ground one and test for spark between ground and the other wire.
            To test for continuity, test between the two spark plug wires.
            You cannot test one wire at a time.
            T
