Home › Forum › Ask A Member › Looking for a Inboard guy
- This topic has 10 replies, 6 voices, and was last updated 8 years, 7 months ago by
rco.
August 13, 2017 at 2:27 am #7887
I am wondering if anyone here is also into inboards? I am trading a guy for a chevy 350 engine for a VW TDI I have and I kinds want to build a old school inboard boat.. nothing fast going to limit the engine down from a 4bbl to a 2bbl and 2500RPM vs 4500 or so..
I’m looking for someone who knows about this stuff to get idea of what I’m in for.
August 13, 2017 at 8:42 pm #62999I’ve worked on a few inboards for friends and neighbors, so I know just enough to be dangerous. I also am on my 2nd inboard/outboard that has a 4.3 liter Chevy V6 built up by Mercury for their MerCruiser system. There is a lot more to an inboard engine than just hooking up a car engine, especially where safety in involved. If the motor is going to be in an enclosed space, you will need water-cooled exhaust manifolds and spark arresting air cleaner (the air cleaner is law in most states and with the coastguard). You will need rubber fuel line approved for marine use. Check out how cooling water gets to these inboards too. Most have an impeller and an automotive type water pump. You also need spark-arresting screens on the alternator vents. Need a blower to purge air from the motor enclosure for a couple minutes before starting in case gas vapor has accumulated. Most inboards and inboard/outboards use a 150 degree thermostat. Best if you find a junk inboard boat to donate the drive system, prop, steering with rudder, and other stuff, some of which is mentioned here. If the motor is not covered up, and you are looking at straight out exhaust pipes used in racing, etc., be advised they are illegal due to the sound level.
A lot of today’s name brand inboard boats use engines by Pleasure Craft http://www.pleasurecraft.com They build auto engines up for marine use. My neighbor’s Ski-Nautique from the 1970s has a Pleasurecraft Ford V8.
Back in the 1950s/1960s, magazines like Popular Mechanics had plans to build many types of boats. These and other plans are available at Glen-L and Clarkcraft, and probably others too. Many of these were inboards. I recommend you look into some published plans and see what all goes into an "old School" inboard. There are kits available too from some of these companies:
http://www.glen-l.com/designs/inboard/inboards.html
An old school inboard canbe a very cool, fun boat if done right!
Good Luck!
DaveAugust 14, 2017 at 3:04 am #63048(In Minnesota, at any rate) people are always essentially giving away 4, 6, and V8 stern drive boats. I assume you are planning a straight inboard or v-drive, but a stern drive boat could give you most or all of the stuff needed for a safe and legal marine installation of an auto engine. Manifolds, marine certified electrics, spark arrestor, manifolds, etc. Most Mercruiser stern drives have the raw water pump in the drive, but Volvo-Pentas have it on the engine.
August 14, 2017 at 3:39 am #63055i was thinking on a mid engined beast but if i found a older stern drive not on a fiberglas boat i would consider it.. basicly i want something to cruse in not really go a break neck speed. why im planning to de tune the engine as much as i can. why 2bbl carb and most likely a throttle stop. perhaps a prop that would give enough RPM but not as much forward speed for it..
August 14, 2017 at 3:56 am #63058Since marine engine always run under load, a truck cam will give you better bottom end. . . 😉
August 14, 2017 at 4:02 am #63059i was refering to not lugging it along at 1200 rpm all day.. more in the range of 1800-2500 rpm
August 14, 2017 at 3:04 pm #63079If you want that sort of engine, maybe look for an old Graymarine, Palmer, Universal, etc flathead engine with a mechanical gearbox. These are usually conversions of of Continental, International, etc industrial/tractor engines and run in the speed range you are talking about.
August 14, 2017 at 3:29 pm #63081You can get creative and modify the throttle linkage back at the carb to limit speed, but if you limit it too much, you may have trouble planeing it off, but your idea of a low pitch prop helps solve that issue. An old school governor on the throttle would give you full power to plane it off, but still limit RPM to a preset number. As for older stern drives not on fiberglass, there are aluminum stern drives out there – Crestliner made several over the years. I’ve never seen a stern drive on a wood boat.
You may want to avoid the old Johnson I/O stern drives. Word is that they refused to pay Mercury royalties to use their patents and as a result had more complex and less desirable outdrives and power tilt and trim mechanisms. The only positive I can think of on the old Johnson drives was they tilted up a full 90 degrees, getting the prop way high out of the water.
DaveAugust 14, 2017 at 5:04 pm #63088Also heard somewhere that a regular car engine cannot be used sucessfully. I have been told they need an extra 4 thousants ring end gap, plus marine parts to survive.
Reason given to me is that a boat motor is always pushing, where a car has effort at the start, but since it rolls on wheels, it cruises easily when it gets going, thus easier on the motor without overheating issues.
I actually installed a A130 4 cyl volvo motor out of an old 1960’s auto in a bayliner, didn’t last too long… nothing but problems for me. Your experience may be different.
August 14, 2017 at 10:02 pm #63104I’m kinda getting the 350 for nothing so I figured I might as well use it for something..
I would plan to marenize it as I’m only getting a long block..
Engine is out of a van from the 80s and I’m told it was a replacement engine for this van
