Home Forum Ask A Member Looking for Bigbird
  • #5138
    htbboats
      Hi all,
      New here! I was refered to this forum from another. I’m looking for Bigbird in refference to parts needed for a GT300PLESB, gearcase or gears?
      Anyone that can help out ?
      Thanks Boathead
      #43180
      Casey Lynn
        Contact T2Stroke. That would be him.
        #43196
        dan-in-tn
          I understand you are looking for gears for V-8 outboards? They are still available, just expensive! The later versions are 2/5 degree lug engagement like stern drive, but will work. You might look on Ebay to see if something is there at a more reasonable price.
          Late model part numbers:
          #435120 forward/pinion gear set – 1 set on Ebay
          #336569 reverse gear
          #337774 shifter readily available
          Early model part number:
          #394853 forward/pinion gear set
          #330853 reverse gear – several on Ebay
          #337774 shifter
          Dan in TN
          #43200
          htbboats
            Thanks I’ll check on all this
            Mark
