Home Forum Ask A Member scott mac lower unit
  • #5602
    cwalker
      HELP! I have a 12hp scott mac, I’m resealing the lower unit. I was not aware that it has 2 impellers, and I can’t get the impeller cup out of the lower unit housing. Any ideas or methods would be great! Thanks. scott.
      #46773
        one of the impellers is for the pump and one is for the bail-a-matic. I don’t know which one is for which. been about 45 yrs since I worked on them.
        #46778
        retiredoz
          Are you sure it’s supposed to come out ? It doesn’t show up as an item on my parts list. The parts list simply refers to the lower unit housing as the ‘pump housing assembly’.
          The top pump is the bailer.
          #46781
            Some of the Scott liner cups were permanently installed with some kind of epoxy-like sealer to keep the water out from between the cup and aluminum housing. They had a big problem with electrolysis corrosion buildup which would bulge and destroy the liner.
            #46785
            cwalker
              When I try to pull out the driveshaft it comes up so far and it’s like something is hitting on the bottom of the cup.
              #46786
              Tom
                Is the bailer pump housing still in place? If so, it might be the drive pin for the water pump impeller hitting the bottom of the bailer impeller housing.
                T
                #46801
                retiredoz
                  The drawing refers to the top of the gear housing as the ‘pump housing assembly’. Leave the driveshaft in place and slide every thing up ?
                  This motor has the shift assembly setup on the drive shaft, not the prop shaft.
                  #46802
                  retiredoz
                    Sent you a couple emails..
