Home Forum Ask A Member Lower unit leakage
  • #79631
    rjoynt
      I know why they call old outboards ‘time magnets ‘! I used JB Weld aluminum patch. It worked great. I let it set overnight while I slept. Put it in the tank today. It ran somewhat good. The carb does need some attention. But what got me was that it jumped out of gear! The dog looked good when I had it apart, but looks are sometimes deceiving! Looks like I have to go back in the lower unit. But, with the proper tools from Frank (the shift shaft seal tool) and Stevens, the pressure tester, and a great group in this Club, makes it worthwhile and enjoyable!
      Thanks all.
      #79634
        Is your shift linkage worn or loose?
        #79641
        rjoynt
          No. It shows the usual jump out of gear when it is put under load.
          #79647
            Perhaps you just assembled something incorrectly, or did not get the cradle/fork installed properly….Did you get both of the thrust washers on the gears reinstalled? Oftentimes they are stuck in there with oil during disassembly, but can fall out without you even realizing they were there….
            #79662
              If the clutch dog is not held in position by linkage with no play it will jump out of gear. Even with new clutch dog and matching new dogs on the gears.
