Home › Forum › Ask A Member › Lubrication of Magneto Oiler Felt
- This topic has 24 replies, 13 voices, and was last updated 4 years, 10 months ago by
drifter.
April 27, 2021 at 10:12 am #237174
I recently downloaded the manual for my 1952 Evinrude 15 hp. As I was reading it, I noticed that it suggested the following “The magneto is provided with a lubricating felt riding against the breaker cam to minimize wear on the breaker point arms. To function properly, the felt requires an application of light machine oil at least one a year – five to six drops will do. See your Johnson Service Station.”
This is the first I have heard that this is a yearly maintenance task – one which I have never done… Is this something I should be doing? Have any of you actually ever done this?
Curious minds want to keep learning π
Thanks,
MarcBoats: '47 Dunphy, '64 Starcraft
Motors:
'53 Evinrude 25; '54 Evinrude 7.5; '55 Evinrude 7.5; '56 Evinrude 30 Lark; '56 Evinrude 16; '58 Johnson 18; '60 Evinrude 10; '64 Evinrude 40April 27, 2021 at 10:48 am #2371805-6 seems a lot I use 30 grade oil 1-2 drops
I doubt to many people pull the flywheel every year some haven’t for 20-30years !!! by the looks of things
April 27, 2021 at 10:54 am #237181Haven’t heard of anyone doing that before. Usually just a drop or two of oil when the flywheel is off is what I’ve read. Maybe lack of oil is why so many of these felts are found to be disintegrated when working on motors that have sat idle for many years.
Improvise-Adapt-Overcome
April 27, 2021 at 11:26 am #237185http://www.marineengine.com/boat-forum/showthread.php?422341-Oiler-Wick
if the new wick is greased per this old post no oil needed …for a while anyway
today wicks come with new points generally
for some reason I prefer 30 grade oil seems to me it won’t sling away like thinner oils …
up to you π
April 27, 2021 at 11:37 am #237188Five or six drops of oil is absurd. The wick won’t absorb that much. I don’t think I’ve ever added any oil, or possibly a drop maybe. A new wick will have enough lube. Some new points will include a capsule of cam grease, That is preferable to oil. I suppose auto parts stores still sell it in a small squeeze tube??? Not to be confused with cam lube for 4-stroke camshafts.
April 27, 2021 at 11:50 am #2371911-2 drops of thin oil, such as turbine or ATF works for me. Too much oil and your points will burn. Cars and trucks with points ignition never had lubricating wicks and ran for ages with just a bit of grease on the cam.
April 27, 2021 at 7:41 pm #237271I use STP oil treatment for wicks. Kinda between grease and oil.
Just as important…which way do ya aim the wick..some put it against rotation and some put it with the rotation. My 1976 15hp manual says against the rotation.
April 27, 2021 at 8:19 pm #237272For many years I have relubed the wicks by soaking them in melted bees wax. Itβs slippery, and wont sling off after it has cooled. R.T.
April 28, 2021 at 12:01 am #237279well very interesting….Looking at an RD oiler wick it does show it kind of oriented with clockwise rotation looking down
what is the general opinion on this ??
update: see text on qd 10-11s !! hard to tell if against… means against rotation or… “touching” the cam as in leaning against something ??
my english is vague on this π
April 28, 2021 at 8:36 am #237291well very interesting….Looking at an RD oiler wick it does show it kind of oriented with clockwise rotation looking down
Sorry buddy, not clear about what you are asking…..The felt in the picture looks oriented properly though. Looking down on top of the crank, it rotates in a clockwise direction…The wick is oriented to the left of the retainer so it will “follow” the cam.
