Home Forum Ask A Member Mag plate, Gale model 025-3566
  • #191463
    dale
      Removed mag plate to replace coil and did not think to mark alignment with drive shaft casing before removal. Is there a position the mag plate must be before tightening the screw that
      fastens the mag plate to the drive shaft casing, or is this not critical?
      #191464
        Nope, just put it on. Position doesn’t matter as long as the speed control lever points somewhere toward the front.
        #191478
        dale
          Thanks. Really appreciate your response.
