Home Forum Ask A Member magneto Neptune 0B34
  • #23216
    JOSEPH BRINCAT
      Good question John… I suspect that those very energetic (like 6000V) electrons just see the gap (s) as high resistance obstacles. Now if the gap (at either end) becomes too great, as in spark plug wire disconnected we have a real problem because the high voltage WILL find a way to make the circuit and likely it will be somewhere internal to the coil… not good! The same issue as "never pull over an engine with out grounding the spark plug wire". On an opposed twin, don’t even leave one of the plug wires ungrounded, if you value your coil.
      #23218
      JOHN D.
        Good explanation for why some of those coils are found open when you buy an old motor. A lot of people don’t know this and ruin a perfectly good coil.
