Home Forum Ask A Member magneto plate base brass ring up or down ?
  • #224652
      old question…
      does the base ring holding the magneto plate go taper up or down.
      10hp 1956 parts PDF shows taper UP but I think it goes taper down ???
      #224656
        Flat side up, taper side down.
        #224672
          great see picture of a 10hp 1956 evinrude ring is upside down !!!
          mag-ring
          #224711
            Actually, the picture shows the ring as used in other models that used a wave washer (such as 3 hp). It has a step around the edge for the wave washer. The draftsman was too lazy to re-draw it for models w/o the wave washer, figuring nobody would notice. But you and I and others noticed.
            wave-washer
            • This reply was modified 5 years, 3 months ago by frankr.
