Home Forum Ask A Member Mark 15 pee hole
  • #206178
    DONN LINTON
      Can’t find one. Videos show a water stream from the right side. ?
      #206179
      RICK EICHRODT
        I believe that the water tell tale discharge hole is actually in the rear water jacket cover which looks like a cylinder head. Look at the bottom of the cover and you should see a small hole drilled into the water jacket cover and it is angled to the starboard side. Use a drill and clean out the hole as they get plugged up with sand and grit. I am sure I will be staked out face down on the ground over a fire ant hill if I am wrong.
        #206182
          correct.
          #206186
          sparkey
            Yep, there it is. Note that it is drilled at an angle…..so the stream exits at an angle(i.e.right side)
            #206193
            DONN LINTON
              Yep, thanks guys. More to the bottom, I just wasn’t bending far enough !
