The flywheel will only turn 1 and 1/2 turns in both directions. I assume it is something in the gear case, someone enlighten me please. I’m in neutral.
Take the lower unit off and see which way the problem goes. Spin the flywheel and if it is free and turns 360…then problem is in lower unit and you already have it off ready to tear down.
Hopefully It is something binding it up in the gearcase. When my motors wont make a full revolution, it always ends up being a broken connecting rod in the powerhead. š„
-Ben
gear case off and that’s where the problem is. The retainer behind the prop is left hand threads, right? I’ll need to make a spanner of some type and also for the impeller.
