Home Forum Ask A Member Mark 30 distributor removal
  • #5706
    bsplit
      I’m trying to remove the distributor from an electric start Mark 30, and after removing the 4 screws to drop the distributor, I don’t have enough clearance on the bottom to completely remove the distributor. I would try to remove the cap, but I can’t get a screwdriver on the innermost screw. Any help will be appreciated.
      Thanks,
      Jim
      #47528
      PM T2
        Its a real PITA but it can be done. I get them out of there, but it usually involves in undoing some of the throttle or shift linkages in the bottom of the belly pan. I also take the carbs out to give me extra space.
        Tiller models are worse, but I’ve gotten it out of there on those also.
        But I can see why some guys like to take the powerhead off to do magneto work.
        Hope this helps.
        Best,
        PM T2
        #47529
        bsplit
          Thanks for the advice…..I’ve done it before….even on one with a tiller. It seems like on the others, I could remove it after only taking out the four screws, eh?
          #47530
            go from under the pan to get to the cap screws after dropping the mag.
            #47531
            chinewalker
              Try maneuvering the throttle linkage. I found there were spots where the linkage had more clearance and allowed me to remove the mag.
              #47533
              bsplit
                Thanks all….
                #47534
                  is it a FM mag or KEIKHEAFER ?
                  #47536
                  bsplit
                    Fairbanks Morse…..I am going to wait until Spring to go back to work on that motor. I’ve had it about 15 years, and was just wondering if I could get to run. It does have a very weak spark, but does not fire.
                    Thanks,
                    Jim
                    #47542
                      Far easier and less time to remove recoil and then the power head. Also no frustration fighting the 0 clearance to get it out and back in.
