Home Forum Ask A Member Mark 30 Dual Fuel Pumps
  • #10704
    jim-spencer
      Is there a purpose for 2 fuel pumps on the Mark 30? I rebuilt the lower pump and the motor seems to run fine. Is there anything to be gained by replacing the internals on the upper pump?
      #80337
      RICK EICHRODT
        It is my humble opinion that if you do one fuel pump, you should do both as they are linked together. If one fails then it can take the other one down or cause an issue. The diaphragm kits are inexpensive and easy to install, so why not do them both. I have a MK30 and a Wizard Powermatic 25 which have the dual pumps. I have changed the MK30 and when I get to the 25, I will do both of them as well. If the diaphragm is damaged or leaking, it will cause fuel to get into what ever cylinder the pump runs off, so it is good insurance to do both. I am sure others will chime in and have their opinions.
        #80338
          Rick is correct. mark 30’s need 2 for idle because of low crankcase pressure only. sme block s the mark 55 58 etc . but the 40-44 cubes have more crankcase pressure.
          #80340
          jim-spencer
            Thanks for the help. I purchased 2 kits, then put one in my Merc 300. I will get another.
            #80349
              you wont regret it. I would buy a few for stock if you find a good buy.
              #80398
              John Schubert
                Merc did the 2 pump thing for the reasons stated, but really not the case MK30H’s only had one pump & those that did Merc made a cover plate to block off the holes. Idled fine except when we went to full butterfles.
