Home Forum Ask A Member MARK 55 CLUNKS WHEN SHIFTING
  • #211276
      I didn’t spell it wrong. I meant SHATTER, as in break into pieces. I have seen it a few times, once in a Mark 55, as a matter of fact.
      #212379
      jrm80
        JUST AN UPDATE ON MY CLUNKING PROBLEM. I ROUNDED UP AN ALUMINUM PROP WHICH I TRIED TODAY AND FOUND THE CLUNKING SIGNIFICANTLY REDUCED. NOT ELIMINATED BUT MARKEDLY IMPROVED TO AN ACCEPTABLE LEVEL.
        THANKS TO DAVE BERNARD TO POINTING ME IN THE RIGHT DIRECTION.
        #212384
          the only way to possibly shatter a clutch dog on mercs is very high rpms in neutral and then shift into gear.
          #212388
          need2fish
            Is the nose cone on the prop snugged down ? A loose prop-on-shaft can cause clunks while shifting.
