Home Forum Ask A Member Mark 58 A lower unit water impeller housing
  • #4953
    rusty356
      How to remove, I do not have a tool for it and my water pump is not working, all passages are clear, etc. even installen new impeller but does not pump, the impeller housing looks a little bent up and I am guessing the seal below it is bad. I happen to have 2 new impeller units if I can figure out how to get the old one pulled out. Or where to buy a tool to pull it out.
      Any help? or suggestions. Rick Conn Foxburg PA. my email is conn356@ecentral.com
      PS, I run the lower unit with a drill to check if its working and its a no pumping !!!
      #41844
      dockbuster1
        There is a tool that removes the housing but it seldom works the easiest way is to remove the prop shaft and reverse gear remove the pinion bolt and use the drive shaft to pull the w/p housing
        #41846
          call me again Dave.1 914 310 7086.
