Home Forum Ask A Member Mark 7 power head removal
  • #2230
    Doug Wilson
      Trying to remove the power head on my Mark7 from the leg due to a bad water leak between the power head and let. Do not see any way to get the two front bolts without removing the tiller handle bracket. Problem is the two front screws on it are too long to let it come lose about to cut both of them and get it apart but still will be an issue when I go to try and reassemble with new screws. Any suggestions?
      Doug
      Doug
      turned off?
      #21779
        accessed from the bottom of the swivel bracket with a screwdriver if it is original. just tilt the motor up and align. I replace the bolts with allen bolts makes it much easier.
        #21783
        Doug Wilson
          Thanks Dave, was thinking allen head bolts would be easier to reassemble.
          still trying to figure out how to get it apart at this point have not been able to
          get the screws out so I can remove the handle bracket.
          Doug
          turned off?
          #21795
          RICHARD A. WHITE
            Turn the motor upside down……sneaky engineers, placed access holes there…
            classicomctools@gmail.com
            #21802
              believe me and Richard the access holes are there tilt it up and look under the swivel bracket.
              #21813
              Doug Wilson
                Thanks for the info Richard and Dave, will try flipping it over tomorrow. took a break from that part and rebuilt the carb tonight, there was so much gunk in there surprised it even tried to start, return spring on the throttle was broken too. That part is ready and tank cleaned out.
                Doug
                turned off?
                #21847
                Doug Wilson
                  Thanks Dave and Richard, took me all of maybe 10 min to get it apart tonight found that the little rubber washer that goes on the top of the water tube was missing causing the sprinkler system effect from the back of the power head.
                  Now to start reassembling with new gaskets and rubber washer.
                  Doug
                  Doug
                  turned off?
