Home Forum Ask A Member Martin 40 tank seal
  • #7349
    mercuryman
      Will Permatex # 2 seal the gasket on Martin gas tank ?
      #59813
      JOHN D.
        I have used that and aviation form a gasket sealant. It did work but I don’t know how long it will work. I think the cork gasket material by itself would be okay. They both have shelac in their mix.
        #59816
        rudderless
          My father in the year 1971 used epoxy putty..then called Devcon and applied it around the outside where the 2 parts meet. The new owner still uses it and it does not leak.
          #59847
          kevinrude
            I’ve never tried these, but Larsen Outboard Service are THE Martin experts:
            http://martinoutboards.com/product-category/tank-seals/
            #59870
            rpsiii
              The 2 piece cork gasket set from Larson is the way to go.
              While it does take a little careful work to get the two piece tank apart, it does give you a great
              opportunity to get the inside of the tank spotlessly clean
              Larson recommends a light coat of spray on gasket sealer on the gasket upon reassembly
              and you’ll be good for another 60 years.
              (The 2 piece gasket is for the 40/45s and the 3 piece is for the 20)
              If you are serious about not wanting your tank to leak, the $35.00 for the set is money well spent.
              Respectfully,
              mercuryman
                Thanks Bob but its now $45 with shipping.
                #60011
                mercuryman
                  I fixed the leak, first I tried Permatex Moto seal and it leaked. I had a roll of cork gasket material and I made two gaskets for the tank. No leak now, it was time consuming but I have plenty of time,
