Home Forum Ask A Member Martin 45 -40 power heads
  • #5025
    eltoquad
      Can a Martin 40 power head be used to replace a bad power head on a Martin 45?
      #42400
      JOHN D.
        I just looked at my Martin 45 and it looks like it will bolt right up. Not like trying to convert a 60 to a 75 twist shift. On that, part of the shift linkage bolts to the block. The carb on the 45 is different and maybe the magneto.
        #42405
        eltoquad
          I’d really like to hear from some one that knows for sure they are inter changeable. My 45 appears to have bad center main bearing and there is a "good" 40 power head available on e-bay that I’d like to buy if it’s just a swap.
          #42413
          ladler
            Go to Martin outboards.com. contact Russ and he will help you out
            #42426
            JOHN D.
              I was busy this morning. I do have a 40 block that I was going to compare with one that is assembled. Only takes a few screws to remove. I’m not going to do that now.
