Home Forum Ask A Member Martin “60” again (carb)
  • #259070
    jimk
      Can anyone tell me the starting point for the low speed and the high speed jet on a 1950 Martin “60” Tillotson carb? I am not sure where they should be on the initial start. I do know they are 1 1/2 out and 3/4 on a Johnson but not sure where to start on this one. I have a Martin “20” that hasn’t been started yet after redoing the carb on that but thinking it should be the same setting on initial startup.
      #259082
        1/2-3/4 on slow speed, 1 on high speed. Note that the slow speed works backwards on those Tillotson carbs.
        #259099
        jimk
          Thank you frankr!
          #259105
            If its been quite a while since it was lat run
            you may need to replace the poppet valve
            O rings to get it started.
            #259127
            jimk
              I have them ordered. How is it to replace them? Ordered them along with the gasket and carb kit but never messed with anything like poppet valves.
              #259129
                No problem if reinstalling old valves.  New ones must be checked for cam follower clearance.
                #259133
                  It easy enough. They are behind the intake
                  manifold. The valves will come right out for
                  O ring replacement. Its best not to switch
                  them. If the old ones break apart when you
                  remove them your motor probably
                  wouldn’t have started. This is a 75 TS but
                  should be similar to your 60.
                  #259141
                  jimk
                    Thanks again! Parts will hopefully be here this week.
                    #259147
                      Sometimes the valves don’t have o-rings, just metal-to-metal
                      #259152
                      elgin2
                        I have a 40 like that.
