Home Forum Ask A Member Merc 500 rough running
  • #180382
    JASON RASER
      I just rebuilt the carbs, went through the magneto, new spark plug wires, good plugs, have new gas, sprayed half a can of Seafoam down the carbs. It runs on high idle but overall has hard starting and a rough idle then dies on slow idle. Should I rebuild the fuel pump or am I missing something obvious?
      #180385
      Randy in Tampa
        Take off the carbs, take them apart and soak them in parts cleaning solution overnight,wash them and blow them dry with compressed air 😉
        Rotary valve Johnson’s Rule!
