Tricky little devils, they are. Yes, try lubing with a penatrant, to help soften all the old, stiff, grease. Also, check your tab lock washer on the main through bolt and nut. Is it broken? Does it look like somebody putzed with it? The basic plan with this type of recoil is that when everything is lubed and assembled properly, you put a big screw driver in the bolt’s slot, loosen the lock tabs, slightly loosen the nut and preload the spring one full turn. Nut is left hand thread, by the way. (Turn the bolt itself, with the screwdriver, counter clockwise, looking from the top, to preload it.) Then tighten the nut and lock the tabs. Sometimes the tabs break off and it just kind of unwinds it’s own tension.
billw.
