Home Forum Ask A Member Merc KE-4, 1947
Viewing 10 posts - 1 through 10 (of 26 total)
  • #249247
    George Solana
      I actually forgot how, years ago, I got the 4-winged nut off that holds down the flywheel. Before I start tearing it up and going the wrong way, is the flywheel nut left handed thread or right handed? What is the best way to remove the nut? I figure once the nut is removed I’ll need to use a small wheel puller to pop off the flywheel.
      Second question is a source I can get new ignition parts for motor, if anyone can help.
      Thanks for any and all help!
      George
      #249250
        get or make a tool to remove the nut.. right hand.
        which mag do you have ?
        • This reply was modified 4 years, 4 months ago by DAVID.
        #249270
          The October 2020 issue of Antique Outboarder had an article on one way to remove the nut in the absence of having the appropriate tool.
          #249272
            taking off is easy but putting on you need to torque it.
            #249281
              I have made a couple from exhaust pipe, nut and a washer.
              #249282
                True that – getting it off is only half the job!
                #249300
                George Solana
                  Not sure on the mag; don’t recall from the last time I had it apart, and of course can’t tell now until I get the flywheel off.
                  Interesting on the tool. I’ll give it a shot. Thanks to all.
                  #249302
                  George Solana
                    When you pull down the Resourses tab and click on The Outboarder link, it just takes you to a page that describes The Outboarder with no way to look up a certain issue, or any issue for that matter. I don’t know; I’d sure like to read that article from October 2020. Problem might be that I’m trying to access it on an iPad.
                    #249306
                      Here’s a picture I took of that article.
                      IMG_0614
                      #249326
                      George Solana
                        Wow, excellent idea and it worked perfectly without damaging paws. The flywheel came off with a few well placed hammer taps but it became obvious why there’s no spark. Both coil cases are badly cracked and corroded.
                        Know where I can get coils, points and condensers and is there a way to change the whole thing over to electronic ignition? I’d rather keep the original ignition system but if I can’t find the parts I’d switch it over to electronic ignition if possible.
                        Thanks!
