Home Forum Ask A Member Merc KE-4, 1947
Viewing 6 posts - 21 through 26 (of 26 total)
  • #249595
      Points are no longer being manufactured. I know
      of no source for new ones. If yours are unusable you’ll
      need to get some from another motor.
      Both ignition condenser # DR70T and AC Delco #D204
      are suppose to have a value of have.18 to .23 however I
      have never checked either. Tubs
      • This reply was modified 4 years, 4 months ago by Tubs.
      #249607
        if your points are straight spring. they can be had new , curved spring NO.
        Spruce aircraft has them
        #249622
        George Solana
          I received these coils yesterday and they seem to match up except for one thing: the solder button, where you would attach the plug wire, falls dangerously close to the ignition plate at the bottom. It’s not exactly in the same position as the original coils, which I think, are scintilla coils. Does anyone know a way to get around this? Even with the rubber boot (that encases and insulates the plug wire from the housing on the bottom of the coil) attached, the soldered connection would be 1/8” from the metal ignition plate, which, to me….literally begs to short out. How can I get around this?
          I might add that the coil could be rotated 180 degrees, which puts the solder button on top of the coil, but in that configuration it might invite clearance problems with the flywheel. I’m lost here.
          As usual, any help is very valuable and deeply appreciated! Photo attached.
          #249624
          George Solana
            C5007EDF-A7F7-4904-9155-C62A0B14D380
            #249627
              drill a clearance hole for it. then insulate
              #249630
                I believe some people have soldered a copper strip to the button to route
                where they want the plug wire to attach, then tape and insulate
                the copper strip so it doesn’t arc.
