Home Forum Ask A Member Merc KE-4 7.5HP disassembly advice needed please.
  • #8308
    huntleybill
      I have 2 Merc KE-4s I acquired recently. I am having issues getting the motor swivel pipe/pin/tubing or whatever it is called out. I can see someone has tried to pound out the tubing from the bottom and pretty much chewed it up. Is these an easy/safe/better way to get these apart?
      Second question: Is there a tool still available for purchase to take apart the gear box? Looks like a "T" handle that has 2 holes that go into the plate.
      Thank you for your help
      Bill
      #65330
      green-thumbs
        Removal of swivel pin: tap the hollow pin to create a threaded section (7’16" x 20 fine thread usually works. You may need to drill to correct tapping size. Then a section of all 7/16 x 20
        threaded rod, nut, washer and a length of pipe, if it proves difficult apply heat and tighten
        up nut…either swivel pin comes out or you pull the threads. Works for me.
        Removing the water pump cover: it is a LEFT HAND thread so it comes off the opposite way
        There are several ways to soften up a tight cover…HEAT, BEAT and your favorite solvent
        to seep into threads. The Mercury Service Tool can be made (sort of) but, the real problem
        is corrosion between threads of cover and case. Use grease on threads when installing
        cover.
        Water pump housing has two threads so it can be (in theory anyway) be pulled out using
        screws, nuts and a plate drilled to fit over prop shaft with holes for the two screws that
        engage water pump cartridge. Usually the threads in water pump cartridge have been messed up so on to plan B. Pad prop shaft in vise and use soft mallet to drive gear case
        assembly away from water pump cartridge…this will bring out several parts that have
        to be reinstalled in same order…ALSO water pump cartridge has to be installed so inlet
        and outlet are lined up or "clocked" Mark cartridge and case with magic marker or similar
        to make this obvious when installing. Seal is installed in grease chamber side of water
        pump cartridge and this is the way to get at it. Heating case may assist in removal and
        installing. Cartridge is a friction fit in gear case. Take photos to aid in remembering which
        parts go where. If you work carefully this should be a mild learning experience. It is vital that
        you pay close attention when taking it apart so you avoid problems putting it back together.
        When you get it back together and it meshes and turns smoothly give yourself a pat on the back. It is not unknown for gears to be damaged or corroded, bearings to be rusted and
        shafts to be be worn, grooved or rust pitted. It may be more cost effective to seek a good
        used gear case water pump assemby than to track down gears, shafts and bearings.
        Seals them selves are nominal cost but shaft has to be smooth. round and concentric to
        seal lips…If you can make tools approximating the Mercury Service Tool life is easier.
        Louis
        #65331
          In answer to your second question – yes, there is a special Mercury tool. However many Mercury mechanics make there own. It fits several gear cases. . . 😆
          #65332
          huntleybill
            Thank you Louis, I will give that a try.
            Wow Garry. That is a great idea!
            #65408
            huntleybill
              Update!! That home made tool worked great for getting the cover off. Thank you Garry.
              Louis, as for the rest of the disassembly, I am having issues. According to some technical info I found, after taking off the water pump cover, I should be able to "pry the impeller out with a couple of screw drivers" but that is not happening. It looks as if the impeller has a round clip holding it in place and I can’t get it to pry loose. I don’t want to pry too hard and wreck something.
              Also, I tried putting the propeller shaft in a vise and using a rubber mallet to coax it along. When that didn’t work, I tried a metal hammer and a block of wood. Nothing! Next is a torch.
              Stand by…. (with a fire extinguisher)
              #65409
              jw-in-dixie
                If the impeller is shot and not reusable, cut the brass bushing with a Dremmel tool and remove. Save the key. That should ease things a bit. Clamp the prop shaft in a sturdy vise and using a big Mercury hammer and a block of wood, beat the hell out of it. Heat and a strong assistant help. 😉
                (What it says in the Service Manual)
                #65413
                green-thumbs
                  Post a photo of impeller. Round clip does not sound familiar. I have not seen anything but
                  a pin on flat of drive shaft to lock impeller to shaft on KE4. Proceed with caution when
                  you encounter an unusual situation. The water pump cartridge is unlikely to have ever been
                  removed since it left factory so it can be a toughie .but, it is only a friction fit in gear case.
                  Torch may be best option. Be aware that the difference between not quite enough and way too
                  much of anything can be very slight.
                  Louis
                  #65451
                  huntleybill
                    I attached some pictures. The impeller looks good. At least what I can see of it. I’m not sure there IS a ring there. It kinda looks like one but it could be just the end of a bushing. or, something else. Either way, it looks like I get to heat it up. How can you not like fire and a hammer!
                    1bkshlf1
                      I have a scanner wrench made by Wright tools (#9636, 2” model).  It works perfectly.  Its width is adjustable.  Costs about $40 thru White Cap who is distributor for Wright tools.  I needed to tap the end of the tool while holding the tines in the holes with other hand, but it worked perfectly.  I ruined my Mark 20’s plate, but after I found this at a garage sale, I feel good about using it in the future. Here’s a photo or twO
                      IMG_0493
                      Hope this helps
                      #281960
                      1bkshlf1
                        It’s a spanner wrench, not a scanner wrench.
