Home Forum Ask A Member Merc KE4
Viewing 10 posts - 11 through 20 (of 24 total)
  • #253952
    DAN UMBARGER
      I would think so Bob…maybe Dave could confirm the left hand thread.
      #253953
      Boonie
        I have spark. Thanks again Tubs.
        #253958
          Yes Left hand threads on the water pump cover
          #253959
          Boonie
            Compression is 107 lbs on top cylinder and 100 on bottom. I’m thinking anything 100 lbs + is good?
            #253961
              check after you have run it. It has been sitting for a while.
              #253963
              DAN UMBARGER
                OK…several things on this motor…first…yes Dave left hand thread and yes Bob lefty tighty righty loosey…lol…impellar has taken a heavy set and is worn out so I will be ordering a new one. Put the flywheel back on and found that a 1 7/8 12 point socket seems to work good to tighten the nut but what is the torque? Did squirt some fuel in the carb and it started and ran for several seconds so I’m pretty confident it will run in the tank. Cosmetically it’s pretty sound…couple of very small dents in the tank…the shroud seems very good. It’s missing the choke knob,has the wrong bolts for the shroud and has the wrong rewind handle which I think I’ve seen advertised in the outboarder. Are the bolt heads painted the green color from the factory? Have seen them both ways. Will start a thread in the Current Projects section soon so thanks for the replies to date.
                #253975
                  if you are talking about the starter and the lower cowl, NO they are not painted.
                  #254006
                  DAN UMBARGER
                    Yea, that’s what I was talking about Dave…seems that they are 1/4×28 truss head on the pan which is what all the other fasteners look like on the motor. I’ll find some nice stainless bolts.
                    #254007
                      I have the bolts 1/4×28 truss head.
                      1 914 310 7086
                      #254022
                        Sent you a PM. Check your messages.
