Home Forum Ask A Member Merc Mark 5 ~ 6 Ring Compressor
Viewing 10 posts - 1 through 10 (of 26 total)
  • #3076
      Just put my second Merc Mark 5 ~ 6 crankcase back together,
      and struggled both times with homemade contraptions for
      piston ring compressors. Used some aluminum flashing
      on one piston and a plastic band on the other, both
      trying to snug up the rings with tie wraps. It’s
      aggravating keeping the ring gaps on those tiny
      pins!
      In looking at the manual, they show Mercury tool 91-24280
      that looks like it would work slick. I’ve never seen one
      for sale, so I was wondering if anyone has ever made their
      own of the same design?
      Anyone have a good photo of an actual one? I can’t tell
      what’s going on the bottom of the compressor in the photo.
      Is the band adjustable?
      Thanks!
      jasonh
        The bands are specific to piston size. Not adjustable.
        #27779
          Jason, are they made to "hinge open" for easy
          install and removal?
          Thanks
          jasonh
            Yes, they hinge and come apart for easy removal.
            #27785
              The almost bigger trick than good ring compressors is to make some kind of device that will hold the block and crank case more or less aligned, as the come together. This frees up your fingers to guide the rings in with your fingers nails, Popsicle sticks, etc. It also helps to be very generous with the oil.
              #27788
              Goman
                You may try using needle nose vise grips to lock your flashing in place over the rings. Free’s your hands up too.
                #27794
                  Bill, I believe the first one that I tried to assemble
                  I used some long guide bolts, but just ended up
                  getting in the way 🙁
                  Goman, I was thinking of something along that line,
                  but maybe a little fast acting clamp to hold the band
                  tight instead of needle nose.
                  Good ideas, thanks!
                    An old driveshaft in a vice works to hold the powerhead while working on it.
                    #27811
                      Dave, if I work on other one of these little "Marks",
                      I may sacrifice one of my parts drive shafts
                      and weld part of the shaft on a plate that I could
                      clamp or screw down to the bench top. Thanks
                      for the idea. Just got the swivel tube back in
                      the crankcase housing….. will have to invest
                      in a press some day!
                        just use your lowerunit and clamp the DS in a vise. no need to destroy a good DS
